Sold F/S Hifonics Cyclops 4000w RMS @1ohm+ amp cooling enclosure -Look!
ampjunkielikeme
this amp belongs to BassAddictJ . i am listing it for him, so if you have any questions pm him..
900.00 O.B.O. (or best offer) plus shipping
this is a hifonics xx-cyclops 4000 watt mono block amp.
the amp works perfect.
cosmetics- i would give it a 8 out of a 10. it has some scuffs and scratches..
functionality- 10 out of 10.. it has zero problems. works as it should..
the amp comes with a enclosure that cools the amp with 10 fans. it also has 12 blue led light to light up the board at night. all of it is hooked up to a separate relay so it doesn't pull to much current from your remote wire..
it covered in spray bedliner.plexiglass top covering the guts of the amp... looks kinda cool if you ask me...lol
you will never overheat the amp again!..
specs:
# 1500 watts RMS x 1 channel into 4 Ohms (bridged)
# 2900 watts RMS x 1 channel into 2 Ohms (bridged)
# 4000 watts RMS x 1 channel into 1 Ohms (bridged)
# Ultra D Class Design
# Turn On Delay
# Frequency Response 2Hz - 70 K Hz (-3dB)
# Damping >400
# Signal to Noise Ratio >98 dB
# THD + Noise 0.1%
# Variable Input Level 0.2V - 9V (RCA/Unbalanced)
# Variable Input Level 0.4V - 18V (Mini DIN Balanced)
# Full PMW Ultra-Fi Mosfet Power Supply
# Variable 24 dB Octave Low Pass Filter (35 Hz- 250 Hz)
# Variable Bass EQ 0-18 dB (30-60 Hz)
# Variable Subsonic Filter (10-50 Hz)
# Variable Phase Shift (Off/On/Stereo) 0-180 Degrees
# Unbalanced and Balanced Inputs(Requires XX-BLD Line Driver)
# Remote Bass Control Included
# Dual 2 Guage Power Terminals
# 10 G Speaker Terminals
# Suggested In-Line Fuse Rating 300 Amps
Dimensions 11.20 W X 2.60" H X 23.75" L
I bought this off grinder1989. It didnt have the standard mounting tabs and i attempted to make mounting tabs for it. Unfortunately the mounts i made allowed for vibrations to cause some faults and it went into protect. I sent it in to ampjunkie where he and db-r worked on this thing and rebuilt it top to bottom. it might as well be brand new after the work they did.
lilmaniac2 has played around with them. from what i've hear the xx and xxv line are respectable lines from hifonics. only difference in the xxv's are they can take 18v iirc. I ran this xx-cyclops off a 240amp alty and an xs d3100 and i maintained 12.8v-13v full tilt, and my btl got stupid loud. i preferred this amp over my old mojo 4kw hands down. I cant recall where i read up on it but i remember the xx-cyclops being clamped and doing rated power at full tilt. To the ear my btl 15 with this amp was just as loud as my older 4hp doing just over 146db around 40Hz.
I ended up spending more than I could afford with this and that's why its up for sale. if it doesn't sell in a month or so i'll end up keeping it and eating lightly for a while //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ampjunkielikeme
ampjunkielikeme
nash, tn
BassAddictJ
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
