Sold F/S Eclipse CDMT 5505
  • Thread starter Maxchef
  • Replies 0
  • Views 434
Maxchef
This is an excellent head unit for the sq'er who wants to have the benifits of a double din without sacrificing quality. I am new here but am well know with others on this and other forums. If you need refrences i am happy to give them to you. I have used this unit for less than 6 months an is in or near mint condition. I am asking $750 OBO for it, brand new its $799 plus shipping from Japan, so roughly $900 new. I am looking to replace it with a Denon or Nak so i might be willing to accpect a trade.
Here are some specs:
E5505CMT is Eclipse's all new 2005 hottest Multiple control CD/MD/MS 2-Din Receiver features a advance MOS-FET 50W~4ch power amplifier that supports high quality sound as well as strong and powerful bass. Features an ultra stylish acrylic panel face design build-in with an ultra high-resolution Dual VF Display. Adopts 5 different kinds of background color. Through internet, you are able to upload and choose the right car interior of your car, Eclipse E5505CMT will automatically adjust to the right sound field. You can also design your own motion picture and upload it to the system by Sony MemoryStick. With Pro Mode function, when the speakers' positions aren't the same, the system will automatically adjust each speaker's output allowing the sound field to stay normal.
CD-R/RW
MDLP
EasyTime Alignment
3 Way X-cover
2Mode SoundControl
ESN
Specifications
CD section
Wow flutter: Below measurement limit
Frequency characteristic: 20Hz - 20kHz
Signal-noise ratio (IHF-A): 100dB
Dynamic range: 98dB
Distortion factor ratio: 0.002% (1kHz,0dB)
MD section
Signal-noise ratio (IHF - A): 100dB
Dynamic range: 98dB
Distortion factor ratio: 0.02% (1kHz,0dB)
MS section
Dynamic range: 98dB
FM tuner section
Frequency characteristic: 30Hz - 15kHz
Practical speed: 13dBf (new IHF)
Reception frequency: 76.0 - 90.0MHz
AM tuner section
Practical speed: 20 ƒÊ V (Signal-noise ratios 20dB)
Reception frequency: 522 - 1629kHz
Audio section
Installed capacity 50W~4 (MOS-FET)
Conformity load impedance: 4 Ħ
DSP section
Signal-noise ratio (IHF-A): 108dB
-PEQ
PRO MODE OFF
-Adjustment center frequency: 63 - 16kHz
-Band: 7Band
-Q: 3 stages
-Tone change quantity }10dB (1dB step)
PRO MODE ON/3WAY
-Hi=200Hz - 16kHz and MID: 63Hz - 16kHz
-Band: Hi/Mid each 5Band
-Q: 5 stages
PRO MODE ON/2WAY 4SP+SW
-Front: 63Hz - 16kHz and Rear: 63Hz - 16kHz
-Band: Front/Rear each 5Band
-Q: 5 stages
-Time alignment
PRO MODE OFF
-Only simple time alignment
PRO MODE ON/3WAY
-Function: Hi-L/R, Mid-L/R and Low-L/R
-Time 0.0 - 10.0msec (0.10msec step)
-Level 0 - -30dB, - XXINF
-Function: Front/Rear/Subwoofer
-Channel divider
PRO MODE OFF
-Cross point frequency
-63Hz - 200Hz (1/3oct step)
-Slope: 6,12,18,24dB/oct & Pass
PRO MODE ON/3WAY
-Cross point frequency: Hi-HPF: 200 - 10kHz and Mid-LPF: 200 - 10kHz / Mid-HPF: 63 - 200Hz and Low-LPF: 63 - 200Hz
MODE ON/2WAY 4SP+SW
-Cross point frequency: Front-HPF: 63 - 10kHz / Rear-HPF: 63 - 10kHz / Subwoofer-LPF: 63 - 200Hz
Common section
Size: 178 (W) ~100 (H) ~165 (D) mm
Mass: Approximately 2.7kg
Power supply voltage: 13.2V (11 - 16V)
Largest consumed electric current: 12 A
Accessories
Main unit, manual, warranty card
Colors Available
Black
http://i32.photobucket.com/albums/d24/maxchef/newinstallpics063.jpg
http://s32.photobucket.com/albums/d24/maxchef/?start=140
Chef
Maxchef
Maxchef
Kansas
Maxchef
