Due to the overwhelming response I decided to repost this with pictures. The subs are designed for SQ applications. They sound amazing and I hate to part with them. They come with everything. Bought from ENG at mobilesq. I have a pair. If you only need one then buy one.
Price $200 each OR MAKE ME AN OFFER
Speaker type : Subwoofer
Impedance : 2 x 4 ohm
Size : 10" (25 cm)
Power handling capacity : 500 W RMS / 800 W max
Voice coil : 3" diameter, 40 mm of length
Frequency range : 25-2500 Hz
Sensitivity : 88,2 dB (1W/1m)(using dual voice coils)
Magnet size : 180 mm (7,08"), 180 oz / 5,1 kg
Outer diameter : 266 mm (10,47")
Installation depth : 133 mm ( 5,24")
Mounting hole : 236 mm (9,29")
Weight : 9,5 kg (20,9 lb)
X-max : +- 14 mm (0,55")
Parameters with voice coils connected in parallel:
Fs: 43,5 Hz Re: 1,7 Qes: 0,51 Qms: 3,72 Qts: 0,45 BL: 9,21 Vas: 26,75 l (0,95 cuft)
Rec. vented box with voice colis in parallel : Vol. 31,65 l (1,12 cuft). 3" port, 18 cm (7") long. F3=39,3 Hz
Rec. sealed box with single voice coil : Vol. 28 l (1 cuft). F3=52,7 Hz
Rec. sealed box with voice coils in parallel : Vol. 17,4 l (0,61 cuft). F3=73,4 Hz
Size : 10" (25 cm)
