Sold *F/S: Clarion RK1 Rem.Start/Keyless :F/S*
SethPhillips
I'sa Playa
BNIB Clarion RK1 Remote Start / Keyless Entry.
Unit Info Here.
$100.00 shipped P.M. Me with offer's.
Warming up your engine isn't the only benefit of ProSecurity's remote engine start system. Set your vehicle's climate controls to either cool off or heat up your vehicle's interior when your engine is remotely started, assuring complete comfort. And with ProSecurity's open architecture design, you get the flexibility you need to add additional comfort features such as remote window control and trunk release.
Two 4 Button Remotes
2 Auxiliary Outputs
Turbo Timer
Compact Satellite Relay Pack
Driver’s Door Capable
Anti-Code Grabbing Technology
Individual Remote Recognition
Remote Enable Valet
Hyper Blue Status LED
Remote Panic
ProSecurity Programmer
ProSecurity Power Up and ProSecurity Starter Disable
Selectable Ignition Controlled Door Locks
Extended Range Antenna
Anti-Grind Circuitry
Tach or Voltage Sense
Selectable Run Time
Factory Alarm Interfacing
Custom Auxiliary Configuration
Gas or Diesel Compatible
Short Run
Rear Defroster Activation
Over Rev Protection
Will this work on a 2004 Grand Prix GT? Anything special needed, or just the unit itself? Install cost?
you are going to need a bypass, to allow tha car to start w/out the key in the ignition.
prices on part's and install should very from state to state.
bump!
i allso have the parts you need i could sale so you have everything needed to have it or to install it urself.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
