Sold F/S: BLOWN Planet Audio BB150.4
rtillaree
F***, Strong
I bought this amp refurbished from IonSQL about 3 years ago maybe. Right after I bought it, some stuff came up and ultimately it took me a long time to finally connect the amp in a setup and try it.
I hooked it up to a setup and it was screaming, very loud and very clean, not too long after though, I heard a pop through the front stage (no rears at the time) and then that was it. No smoke, no funny smell, just no power. I opened it up, nothing appeared to be burnt up visually. Once I opened it up, I did noticed two resistors were rolling around inside, these resistors are photographed below. I’m no expert, but this might be related to its lack of functionality //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
• 4 X 150 W RMS @ 4 Ohms
• 4 X 300 W RMS @ 2 Ohms
• 2 X 600 W RMS @ 4 Ohms Mono
• Dimensions 16-5/8" (L) x 2" (H) x 6-1/2" (W)
• Signal To Noise Ratio 102 dB
• Frequency Response 20 Hz to 20KHz
• Tri Mode Capability
• Line Out with Low/High Pass Crossover
• Switchable Input Sensitivity 100mV-2V or 2V-8V
• Built-In Continuously Variable Low Pass Crossover 18 dB/Octave
• Continuously Variable Bass Boost 0-12 dB
• Chrome Plated Connectors
the amp has some scratches and scuffs which can be seen in the photos, this is pretty much how it came when I got it, it is also a little dusty.
if you have any questions, please PM me.
$50 shipped via UPS ground/no trades.
rtillaree
F***, Strong
rtillaree
Orlando
rtillaree
