Sold F/S: Blown H2 and L7's
937DYTBOI
TL>you
i have an 10" Orion H2 dual 2 ohm subwoofer that is basically lown, it really needs to be recoiled, both the Orion and L7's recieved bad power in which fried them. The L7's are a pair of 15's and i beleive they are dual 2 ohms these also had bad power o through them and probably need some work done to them, also i used the wire off of one of the L7's which connects the tensil to the subwoofer. If you have the capabilities of getting these things fixed u can have them for a good price or u can use these things for parts, all subs in great condition by means of the cone no rips or gashes in cone. Im asking $25 for each sub
i believe a recoil because if u look inside at the coil u can see that its all loose and unraveled, if u push in on the cone u can hear the coil making like that scratchy noise, im trying to describe it the best way i can not being right by the sub and not plaing wit it for about 9 months, i will get a better description of whats going on this evening
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
937DYTBOI
