f/s aeromotive fuel pump controller
  • Thread starter honkyg
  • Replies 0
  • Views 278
honkyg
uncle ofay da kracka
i have a bnib, aeromotive 16302 fuel pump controller that was purchased as a set along with an aeromotive a1000 fuel pump, i dont really need it now, so anyone interested can pm me. original cost is $277 (+/-) im asking $150
excerpt: (For any pump, on any type of vehicle, the Aeromotive Fuel Pump Speed Controller (FPSC) minimizes hot fuel handling problems for in-line pumps in bypass systems and it will also keep T-style pumps cool in static systems, extending fuel pump life. Sensing engine RPM, the FPSC kicks your fuel flow into high gear when you need it, but reduces pump speed and flow to keep things cool when you don't. It's like an automatic transmission for your electric fuel pump.
When you're cruising, Aeromotive’s Billet Fuel Pump Controller automatically steps voltage down to the Fuel Pump at lower RPM, then it continuously monitors engine speed, stepping voltage and flow back up when needed. The RPM step-point is adjustable, allowing calibration for your specific application.)
comes with all necessary wiring and bypass switch
no instructions, but a link to the pdf. (http://www.aeromotiveinc.com/pdf/16302.pdf)
honkyg
honkyg
under your bed and in your nightmares
honkyg
