Sold F/S: 2 Blaupunkt ODW1000hp's 10" subwoofers
pickup1
2. Specs: 10" 4-ohm subwoofer with protective grille
* aluminum diaphragm bonded to inner foam core
* foam front and rear surrounds
* can be used in free-air applications
* frequency response: 20-200 Hz
* power handling: 50-200 watts RMS
* peak power handling: 600 watts
* sensitivity: 90 dB
* mounting depth: 2-1/4"
* sealed box volume: 0.4-1.4 cu. ft.
* ported box volume: 0.4-1.4 cu. ft
Size 10 -inch
Impedance 4 ohms
Cone Material Aluminum bonded foam
Surround Material Foam
Sealed Box Volume (cubic feet) 0.4 - 1.4
Ported Box Volume (cubic feet) 0.4 - 1.4
Port diameter (inches) 3
Port length (inches) 9.7
Free-Air Yes
Dual Voice Coil No
Sensitivity 90 dB at 2.83 volts
87 dB at 1 volt
Frequency Response 20 - 200 Hz
RMS Power Range (Watts) 50-200
Peak Power Handling (Watts) 600
Top Mount Depth (inches) 2 1/4
Bottom Mount Depth (inches) 2 11/16
Cutout Diameter or Length (inches) 9 1/8
Vas (liters) 37.5
Fs (Hz) 30
Qts 0.64
Xmax (millimeters) 10
3. Description/Condition: Nice,got them from a well known member and only 5-6 months old.Will come with origional boxes and the grills too!
4. Price: :140 shipped o.b.o.!
pickup1
pickup1
Polk City Fl
pickup1
