Sold F/s 06 Re Xxx 12"
Btnhtillidie
I need my back seat in my truck so I need to sale this beast. Less than an hour on it, comes with shipping container. No dings, dents, or anything it is flaw less!
From RE:
Mounting Depth - 12.75”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 10.5”
Motor Depth - 5”
Basket Depth - 7.75”
Displacement - 0.24 cu. ft.
Weight - 72 lbs.
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
$500. Trades considered, looking for a decent 10"sub an amp combo.
Shipping will be high due to the weight. If you live close too the PHX,OAK,PDX,BFI, APA, SLC airports and are willing to pick it up at the airport shipping can be free PM for details.
Btnhtillidie
Btnhtillidie
SO Cal
Btnhtillidie
