Exodus Anarchy
gckless
Just got them today. They are beautiful //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Compared to some Polk dB651's I have:
Those can't possibly sound good, they're 8ohm.
You'll never get enough powerz to them.
I'm excited to see if I can hear a difference with the higher ohm load. I'll be powering them with two channels bridged on a Zed Levi each. Around 300W @ 8 ohms.
I've got a pair of Vifa NE25VTS-04 tweeters and a pair of custom 15" 3HP's on 5k. I've got a half chub thinking about it all.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Iz not a EssQue setup?
Careful with that power. In free air it will only take about 50-75w to stroke them, depending on how low you cross.
Trying for the definition of SQL. They are tuned just under 30Hz, so definitely not all out SPL. The subs were built by Zeus with a bit more SQ in mind. Won't be pushing 5k to them at all times, just wanted some big power available for when I want it.
Got it. I plan on actually running around 200W to them, plus/minus a little depending on how they perform. Gonna be nice to have some headroom.
gckless
gckless
San Antonio
gckless
