Sold EVO / Clarion / StreetWires / Dayton / RD / Sony / Pioneer
RidnClean
Love 4 Money
1. Product:
3 EVO 18s
2. Specs:
Dual 1s
2K RMS
double stitched leads
LVL5 Coils
3 Hard Spiders(used in LVL4XLs)
from Ssackett(builder):
The subs were built to take some power given the physical limits of the motor itself and so on. They were built with the same spider pack and coil as a LVL5 less one spider.. They make awesome daily subs and as Howie can attest take the power they are rated for. I usually rate them for 1500wrms but obviously they can take more if the end user desire to push them harder. I wouldnt push them much past 2000w or so although there are a few guys running this spider and coil setup with this motor running higher.
3. Description/Condition:
1 sub had a bad coil rub and after comp it is now sounding "blown"
scott is sending a fresh recone for it, you can recone it or i will, your choice.
other 2 subs work fine and good condition
4. Price: :
$200+ship each used one
$250+ship for brand new(recone waiting to be glued in)
5. Pictures:
1. Product:
Custom built evo 12 from ssackett
2. Specs:
D2
1000RMS
good condition
been used for the past few months off xsite 2k(i'd give it around 1500rms)
then sat past month or so.
4. Price: :
$200shipped
5. Pictures:
1. Product:
Dayton PA165-8 6" PA Drivers
6 available
2. Specs:
Parts-Express.com:Dayton PA165-8 6" PA Driver | 6" woofer 6 inch woofer midbass driver pro sound sound reinforcement PA
This unit was designed with the goal of the producing the highest possible output from a driver its size. Great for use in small stage monitors, as a midrange in multi-way systems, or even as a hi-fi midbass. Construction includes a steel frame, paper cone, treated cloth surround, vented pole piece and high-power-handling 1-1/2" aluminum voice coil. Specifications: * Power handling: 75 watts RMS/125 watts max * Voice coil diameter: 1-3/8" *Impedance: 8 ohms * Re: 5.2 ohms * Frequency range: 80-5,000 Hz * Fs: 87 Hz * SPL: 91.9 dB 1W/1m * Vas: .28 cu.ft. * Qms: 2.92 * Qes: .66 * Qts: .54 * Dimensions: Overall Diameter: 6-1/2", Cutout Diameter: 5-5/8", Mounting Depth: 2-1/2".
mint, like new, 1hr of play time.
4. Price: :
$45shipped a pair
5. Pictures:
1. Product:
Clarion EQS746
2. Specs:
7-Band Rotary Equalizer
12 dB Boost/Cut at 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
Auxiliary Input with Source Select Switch
Adjustable Aux Input Sensitivity
Subwoofer Output Level Control
Gold-Plated Preamp Inputs and Outputs
Rotary Volume Control and Fader
6-Channel RCA Outputs
Selectable 60/90 Hz Low-Pass Crossover
Crossover Slope: 12 dB/octave
Maximum Output Level: 7V RMS
Input Sensitivity: 50mV–4V RMS
Signal-To-Noise Ratio (S/N): 105 dB
Frequency Response: 10-50,000 Hz
Total Harmonic Distortion (THD): 0.005 %
Input Impedance: 10K Ohms
Output Impedance: 50K Ohms
Stereo Separation: 82 dB @ 1 kHz
Dimensions: 7" W x 1" H x 4" D
good, lil dusty but i'll clean it up
4. Price: :
$45shipped
5. Pictures:
1. Product:
StreetWires ANL 150a Fuses
2. Specs:
Designed for the highest-power mobile audio systems
Integrated viewing window for easy fuse inspection
High-temperature, impact resistant polymer bodies
Screen-printed StreetWires logos and amperage ratings right on the fuse
BNIB
4. Price: :
$50shipped for all
5. Pictures:
1. Product:
Sony CDX-CA850X
2. Specs:
Sony CDX-CA850X CD Receiver with CD Changer Controls at Crutchfield.com
detachable, fold-down face
multicolor display
SSIR-EXA tuner
18 FM/12 AM presets
EQ7 features 7 bands of EQ (+/-10 dB at 62, 157, 396, 1,000, 2,500, 6,300, and 16,000 Hz) and 7 EQ presets ("Vocal," "Club," "Jazz," "New Age," "Rock," "Custom," and "Xplod")
Dynamic Soundstage Organizer
plays CD-Rs
front/rear sets of 2-volt preamp outputs
2-volt subwoofer outputs
TV/CD/MD changer controls
wireless joystick remote and handheld remote included
clock
23.2 watts RMS/52 peak x 4 channels
CD frequency response 10-20,000 Hz
CD signal-to-noise ratio 90 dB
FM sensitivity 8 dBf
Condition: good, very light scratches on face you cant really see
trim ring is glued on, but still removable.
comes with trim, cage, remote, harness
Enhance your on-road safety with the revolutionary Sony Xplod CDX-CA850X. All receiver controls are located on the ergonomically-designed wireless joystick remote, so the entire front panel of this cutting-edge CD receiver is one big, bright, highly-visible multicolor display! The joystick remote can be positioned for ease of use, and each function has its own distinctive "feel" and location — you can keep your eyes on the road rather than on your receiver. A full-function handheld wireless remote is also included.
The built-in amplifier (23.2 watts RMS/52 peak x 4) reproduces your music with precision and authority. Press a button, and EQ7 brings 7 preset curves and a 7-band equalizer into the mix for sound-shaping. Switch to DSO, and the Dynamic Soundstage Organizer raises and widens your speakers' apparent location for more spacious sound. Add a CD or MD changer to your receiver order, and get an instant discount!
4. Price: :
$150 OBO
5. Pictures:
1. Product:
RD Audio D9
2. Specs:
RMS power, 2 ohm linkable/dual mono RMS power, .75 ohms mono 5400 RMS power, 1 ohm mono 3600 RMS power, 2 ohm mono 1800 RMS power, 4 ohms mono 900 Signal to Noise Ratio >100dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
good
4. Price: :
SOLD
5. Pictures:
1. Product:
pioneer ts-w255dvc
2. Specs:
Nominal Power Handling 350 Watt RMS
Peak Power Handling 700 Watt
Frequency Response 18 Hz - 2.5 kHz
Sensitivity 87 dB
Impedance 4 ohm (Dual Coil)
good
4. Price: :
$130shipped
5. Pictures:
RidnClean
Love 4 Money
RidnClean
Washington
RidnClean
