EU 700's
bumpin_blazer
Only the Strong Survive
Who here has used them? Do they do well in IB setup? I'm looking for a solid mid for the rear cab of my truck. I figure i'm using a 6 channel amp and these will do well with the 120 per i'd feed them. So opinions and or experienced peeps let me know if these are worth 120 bucks for a pair.
120 for a pair? they are 50each shipped from ED!
http://edesignaudio.com/product.php?cid=15&pid=32&cur=USD
I have them as subs and they are badazz! I think you could have an extreamly strong mid stage with them too. You definatly will have no problem with them picking up where your subs leave off.
I am waiting for my sub amp and will be running 6 of them for substage when it arrives. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
120 for a pair? they are 50each shipped from ED! http://edesignaudio.com/product.php?cid=15&pid=32&cur=USD
they are 50 each plus shipping
~Magick_Man~
so i have 1 negative, 1 positive from someone it seems hasn't used them. the terminal's aren't a big deal as i sorta like the push pin terminals. i'm mainly looking for a 2ohm or dual 4ohm mid that can wang and be done IB.
i have two for my mids in the front 200 watts a piece.. dual 2 ohm .. orion 4002 amp ..its a dedicated midbass in a 3 way system, dont get it twisted .. but they work great.. esspecially for showing off a lil extra something ..
if i got them they'd go in the factory rear cabin location. only reason i'm thinking against it is b/c i'm going with a single DD 10" in the back and i'm just not sure if they'd overpower the EU's.
i got two of the as sub duty in the winter cuz i take the 9500's out and they make things move you can check my vids out over at RoE under the name mtxthunder9500 in the eD section of the vids
is 100 or so a piece good enough? i know they're rated at 150 but i figure 100 should do fine. is anyone running these IB i haven't found an answer to that yet.
Its just that the holes are super small ( 16 ga) and they are mounted close to the side so if you arent careful its really easy to rip off the wire
Dude, were talkin about a small driver here...not a 15" sub. Of course you gotta be careful with it. Have some patience.
they are rather small and they are kind of a pain in the *** with the terminals being the way they are but like said above have patience with them and you should love them
bumpin_blazer
bumpin_blazer
Austin,TX
bumpin_blazer
