Esoteric HT theater
thylantyr
Once in a while I stop at that forum when bored to do this ----> //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
or find cool stuff and do this --> //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
In this case .. it's --> //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Post #2
http://www.avsforum.com/avs-vb/showthread.php?t=657782
Two questions in my mind.
1. I wonder how many items I can delete from that list and still have the
same AV experience?
2. Of the remaining items, how many can be replaced with lower cost items
to still have the same experience?
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Look the mods or tweaks done to equipment.
hint: anything with the word Bybee is snake oil.
First line;
AUDIO PROCESSING:
Theta Casablanca 3 surround processor (with 2 Xtreme DAC cards with 8 Xtreme balanced channels for five main speakers, and three discrete subwoofers for front left, front right and surround subwoofers). Tweaks: Symposium Rollerblocks, Symposium Ultra Platform, Bybee AC Charger Filter, Granite Audio 560 10 guage power cord, uses PS Audio P600#1 (used for non-video front end components) set at 60 Hz sine wave, and Bright StarLittle Rock 2 on top of four Symposium Cubes.
That one tweak is at least $300.
http://www.enjoythemusic.com/magazine/equipment/0401/symposium.htm
Symposium Rollerblocks Series 2 equipment support system ($299 with standard chromium steel balls, add $75 for tungsten carbide balls upgrade). As seen above, there is a high-precision polished cup area for the ball to rest upon. The Rollerblock's body is constructed of a a one-piece "unibody" design so that the cup section is carved out then precision polished. The matrix of holes on the bottom also also cut out of this single solid block, later being filled the foam material. This arrangement of the holes acts to suspend the cup area over a series of parallel and irregularly shaped pillars, which in turn act as a "waveguide" to improve coupling efficiency with the surface it is resting on. With the platform and Rollerblocks used in concert you get a complete system of isolation plus coupling. A "draining" of chassis and also reduce the affects of air borne vibrations.
Expensive and esoteric item to place your 'source' on for isolation..... I use a $2 towel under my CD player, works great. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
honestly i think all that crap is mumbojumbo that is not worth the money they used to build it.
jesus.
if anyone can CLAIM they can hear some minute difference with that **** ill laugh my balls off.
thylantyr
thylantyr
[Yoda] Belong to us all your base are...
req
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
