Epson Projector, ENJOY!!!!!
Ali1
e6300 FTW
i got this epson emp-61 projector, one of the best i've used compared to the other 4 i've owned. I hate to let this go, but i can use the extra cash and live with my 32'' t.v. in the meantime. if you guys are interested, shoot me a PM. Its $425 shipped. it comes with the power cable, and if i could find the rest of the wires, i will include those as well. Trades are welcome, but cash would be real niceeee
SVGA 2000 lm
Easy to Set-up
Large, well marked buttons
Quick start-up and cool-down
Auto keystone correction
Source search
Single-foot release lever
Comfortable Viewing Environment
Brightness control
Powerful 5W speaker
Frontal exhaust and minimal light leakage
Six selectable projection modes
Convenience Features
Security functions
Straightforward and easy-to-use help
EMP monitor compatible
Simple lamp replacement
Short throw distance and wide 1.2x zoom ratio
Full input/output functionality
Direct power-on
Audio
Built in speaker Yes
Number of speakers Mono
Bandwidth
Horizontal synchronization range 50-120 kHz
Vertical synchronization range 15-107 Hz
Bandwidth 230 MHz
Connections
VGA (d-sub) input 2
VGA output 1
Component (3xRCA) input 1
Composite (yellow RCA) input 1
Computer audio (mini-jack) input 2
Image resolution
Brightness (whisper mode) 1500 ANSI lumens Sometimes the projector can be set to run in low brightness mode, with lower fan noise.
Maximum resolution UXGA (1600x1200) Most projectors automatically accept images that are of greater resolution than the native (true) resolution of the projector. The resulting image is scaled to fit the native resolution of the project ... More info
Aspect ratio 4:3 The most popular aspect ratio is 4:3 (4 by 3). Early television and computer video formats are in a 4:3 aspect ratio, which means that the width of the image is 4/3 times the height. Examples: A ... More info
Supporting aspect ratios
Minimum image size 30 inch Image size is measured diagonally over the image.
Maximum image size 300 inch Image size is measured diagonally across the image.
Minimum projection distance 0.9 meters This is the closest distance from the screen where the projector can focus.
Maximum projection distance 11.0 meters This is the greatest distance from the screen where the projector can focus.
True Widescreen No Shows if the projector supports real widesceenformat 16:9 this may be important for home entertainment systems.
Standard Resolution 800x600 SVGA All projectors have a native or true resolution. This is the standard but most projectors support other resolutions. A projector is best viewed in the standard resolution.
Brightness 2000 ANSI Lumen A standard for measuring light output when comparing projectors. Unfortunately, there are enough variables, that the eye will often disagree radically with the ANSI rating. If however one projector us ... More info
Contrast (full on/off) 400 :1 The contrast is the relationship between the brightest possible output, and the darkest possible output.
Lens/Zoom
Zoom Power
Digital zoom possibilities Indicates if the projector has digital zoom or not.
Measures
Width (in) 13.0 in
Height (in) 4.29 in
Depth (in) 10.0 in
Weight (lb) 8.82 lb
Full HD (1920x1080) No
Power consumption 280 Watts
Lamp effect 200 Watts
Lamp life 2000 h
Audible noise 36 db
Audible noise (whisper mode) 30
Ali1
e6300 FTW
Ali1
U.S.
Ali1
