Epson Powerlite S3 SVGA Video Projector
XanderMoser
Poor college student
I am getting more into car audio and less into home theater, so I'm trying to sell some of my "dorm theater" equipment.
I am asking $375 for the projector and all of the equipment that it came with. If it helps I'll throw in a 12' s-video cable and an s-video booster too...
However, I will possibly take trades and money...I'm looking for some amps right now:
2 channel bridgeable to 300 watts rms or more
or
mono 300 watts rms or more
Back to the projector...
I have owned this projector for just over a year, and it has less than 550 hours on the bulb. All of those hours are on low brightness. The bulb is rated for 3000 hours at low brightness, so I have used less than 20% of the bulb life.
It has one single stuck pixel. Not a big deal, most people don't notice it until I point it out.
You can find all the details on the projector here:
http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=53540923&category%3Cimg%20alt=%22=P%22%20%20src=%22./images/emoticons/tongue.gif%22%20/%3Eroducts
Here are the projector's "brief" specs:
Projection System
* Epson 3LCD technology
LCD
* Driving method: Epson High Temperature Poly-Silicon TFT, Pixel number: 480,000 dots x 3 (800 x 600), Native resolution: SVGA, Aspect ratio: 4:3 (supports 16:9), Pixel arrangement: Stripe
Lamp
* Type: 135W UHE, Life* 2000H (High Brightness), 3000H (Low Brightness)
Screen Size: (Projected Distance)
* 30" to 300" (2.9' to 34.4')
Brightness: (typical)
* 1600 ANSI lumens (High Brightness), 1400 ANSI lumens (Low Brightness)
Contrast Ratio
* 500:1
Weight
* 5.6lb
Fan Noise
* 36db (High Brightness), 28db (Low Brightness)
Effective Scanning Frequency Range
* Pixel Clock: 13.5MHz to 162MHz, Horizontal 15KHz to 92KHz, Vertical 50Hz to 85Hz
Remote Control Features
* Features: Zoom, source selection, power, page up/page down, color mode, volume, e-zoom, a/v mute, freeze, resize, menu, help, auto, mouse functions; Operating Angle: Right/Left +/- 30 degrees, Upper/Lower +/- 15 degrees; Operating Distance: 19.7 ft (6m)
RGB
* Analog RBG I/O
o Display Performance: Native: 800 x 600, Resize: 1280 x 1024, 1024 x 768, 640 x 480
o Input Terminal: Video: Mini D-sub 15 pin x 1, Audio: Stereo RCA x 2 (White/REd)
* Output terminal: Video: mini-D-sub (monitor out) x 1
Video I/O
* Display Performance: NTSC: 550 lines, PAL: 550 lines (Depends on observation of the multi burst pattern) Input signal: NTSC, NTSC4.43, PAL, M-PAL, N-PAL, PAL60, SECAM, HDTV: 480i, 480p, 720p, 1080i, Input terminal Video: Composite Video: RCA (Yellow) x 1; S-Video: Mini DIN; Component Video: Mini D-sub 15pin (in common with Analog RGB connector); Video-RGB: Mini D-sub 15pin (in common with Analog RGB connector) Audio: RCA(Red/White) x 2 (in common with Analog RGB connector); Audio signal: 500m Vrms/47Kohm
Control I/O
* USB 1.1 connector Type B x 1 (for mouse/keyboard control)
If you want to know anything else, let me know. I can take any pictures you want.
Pictures...
Includes projector, soft carry case, cd and all manuals, remote, VGA cord, and power cord.
I'm sort of new to this selling on forum thing. So I didn't think of doing this but noticed that other people do. So here's another pic with my name, date, product just to prove that I actually have this. I really want to sell it to help out with fixing my crappy car audio. You'd probably cry if I said what I have in there right now...
Anyway, here it is.
XanderMoser
XanderMoser
Wisconsin
XanderMoser
