Enclosure for 4dr jeep wrangler..
FineLinePimpin
Stuck in WV
Well i have two Skar Ma-8's and was wanting a quote on a box for them...
Vehicle Make and Model:2012 Jeepr wrangler unlimited...4dr wrangler..
Direct of Box/Subs:rear facing..if thats what you mean...sorry lol
Sealed or Ported:ported
Number of Subs:2
Brand and Model of Subs:Skar MA-8 Dual 4ohm voice coils...will be wired to 1ohm
Max Dimensions:these are the max dimensions I have to work with... up to 36in wide across the face of the box,11-12in max deep ,12-14in max high.
Port Color:black
Flush Mount Ring Color (if flush mount is chosen):flush mount not needed
Carpet Color:black
Zip Code for Shipping Quote:25413
here are skar's specs for the sub and box reccomendation....
Outer Diameter : 8.5" (216mm)
Mounting Depth : 5.7" (145mm)
Magnet Diameter : 6.3" (160mm)
Subwoofer Cut Out Diameter : 7.4" (188mm)
Subwoofer Displacement : 0.10 Ft^3
Sealed : 0.30-0.40 Ft^3
Ported : 0.50-0.75 Ft^3 @ 34 Hz
*Due to the extreme power handling of this 8" Subwoofer, we recommend that you follow our enclosure size recommendations specifically. These woofers are made for small enclosures and putting them in larger enclosures could damage the subwoofer. We recommend not going any larger then 0.75 cubic ft (after subwoofer displacement) for a ported enclosure.
T/S Parameters (D2/D4 Ohm)
Re : 4.00 / 8.00 Ohms
Fs : 44.1 / 45.3 Hz
Sd : 20.106 / 20.126
BL : 16.6 / 18.9 N/A
Qms : 4.39 / 3.83
Qes : 0.51 / 0.48
Qts : 0.46 / 0.41
SPL : 81.9 / 85.2 dB
Vas : 5.90 / 5.18 L
Cms : 102.75 / 98.63 uM/N
Mms : 126.54 / 118.5 g
Just let me know what you think the cost of the box and shipping will be.
Thanks, Vince
FineLinePimpin
Stuck in WV
FineLinePimpin
Bunker Hill, WV
FineLinePimpin
