electronic wine?
Does the amp have a fan?
never thought about this, but i had one amp connected before, and now i have 2 connected, and the second has a fan
why dont you take the cover off and try to locate the source by ear.....be careful not to touch anything as it may shock you and/or blow the amp
if i can figure out where the noise is coming from, and take a pic, can someone tell me what the culprit is, and what i can do about it?
A car audio power supply can 'squeek' in sound under load. For instance, lets say you
took the cover off and placed your ear next to the transformer, the toriod. Operate the
amp under heavy load, burp it, you may hear a squeel........ chirp chirp..... for every burp.
This is because the switching frequency is dropping under load and the switching frequency
is suppose to be outside the audible range, way beyond 20khz. Under load, the switcher
may drop in frequency to the audible range, hence the chirp...
This is not a good design and a good amplifier shouldn't do this unless it's broken or something else weird is going on.
But in your case, you hear the amp squeel when the input voltage rises from 12v to 14v,
it also seems like the switcher is having problems with it's switching frequency. The lower
voltage is tweaking the amplifier out when it shouldn't. Maybe something is broke....
Broke-back amplifier?
That's my weird take on this.
dman4486
RememberedHowToChangethis
dman4486
Fountain Inn, SC
thylantyr
