helotaxi
Kilroy was Here
Sounds like a combination of signal distortion, cone breakup from over-excursion and right at the end, tinsel slap.
Qts is .29, EBP of 96.55, vented enclosure all day.Bro... Eclipse Subs DO NOT LIKE PORTED ENCLOSURES ( Anything under the 9000 series that it )... Get them out of that box... and SEAL THEM!
Matter fact, just seal that prefab ported box off... ( put piece of wood of the ports - COMPLETELY COVERING THE PORTS )
... Believe me.. I had 4 of those in a ported enclosure, they sounded like garbage, and was doing the same thing...
SEALED THEM - BYE BYE PROBLEMS - Happy Speakers... Happy Listener...
And you do sound very experienced. Perhaps someday you'll share with us your proposed standard for driver parameters but until then I'll use the current one, lol.I don't care WHAT the qts & EBP says...... I'm telling from experience...
Ported ain't it for this subs.
Lol, dude.I don't care WHAT the qts & EBP says...... I'm telling from experience...
Are you aware that you can still clip the subs and have the same noise in a sealed enviorment? Then what? The OP is out money and time spent on building another enclosure with the same issues.until you go sealed... you're gonna have this problem.... Enough said.
2300 watts will bottom any driver in the world at the right frequency in the right system, you can't just go by an amplifiers RMS spec and assume you're good. You should always model your design (Use WinISD because its free) with appropriate voltage and include high pass protection filters if needed.I've got two 12" eclipse aluminum 88120.4 svc subwoofers running off a hifonics bxi2607d. Every time I turn them up I get a loud clacking noise from both of the drivers indicating that They are bottoming out. The two subs are rated at 500 rms but are known to take almost double of that. My amp pushes out about 2300 rms at 1 ohm which is probably a little too much for the two subs can handle. I have another 88120 svc sub so do you guys think adding another sub will stop the bottoming out by distributing the power more? The reason I'm not going ahead and testing it is because I first would need to build a box to hold the three Subs which is going to take time and money. Any help would be great.EDIT: BXI2607d not bxi2010d
