Eclipse Preout Question
I want an Eclipse CD-8445, but my amp (ED NINe.1) excepts only up to 7v preouts and this thing has 8v preouts, will it be ok? What will it do?
As long as you do not turn the volume up all the way and blast 0db sinewaves you will be fine.
mmm...well c i might do that lol... any other eclipse headunit i could get that has maybe a lil less?
Is really that hard to not turn up the volume all the way? I have an Eclipse 8053 which puts out around ~8.5 volts unclipped at full volume and I am using it with amplifiers that only accept 5 volts. As long as I do not turn it up past 70 out of 80, the amp will not clip. Another option, is just to use attentuation. I do not know if the 8445 can do this, but on the 8053 you can adjust the level of each individual output. This way you can turn down the level of the sub out, to ensure that the HU will only put out 7 volts at full volume.
Another eclipse unit might work, but what features do you want?
I need preouts enough for my front stage comps and their ED NINe.2 theyr running off of, and I need a sub preout for my two ascendant audio arsenals and their ED NINe.1. I need a good LOOKING HU as well, and I need it to be a CD player...well duh lol, umm I need it to be single din, and I need it to play MP3 cds and all that jazz, and I would like outputs to be somewhere from 4-7 volts.. thats about it, so what can get me that?
You'll be fine with that 8v Eclipse. My amps accept 7v and at 70/80 on my 8053 it's pumping out 14v or so with the BLA. Like msimon said, unless you listen to the deck in the 75-80/80 range your amps will never see that voltage anyway...besides that's with a sine wave not dynamic music.
Well with those requirements any number of lower end or older eclipse HUs would work. It all depends on what you want as far as processing.
I have a question on this subject.
I just bought a CD8445 (8V preouts) and I will be using it with an Elemental Designs Nine.4 amp which says 7V max for the inputs. I asked someone at ED and they said as long as I kept the gains on the amp at the minimum setting it would be fine. So does this mean that I wont be able to adjust the gains on the amp at all?
No it does not mean that. Again, the 8v decks put out 8v MAX unclipped voltage when the deck volume as at or near 80/80 while playing a sine wave. Under normal listening to dynamice music it probably puts out like 1-2 volts.
So just adjust the gains accordingly using your ear and/or with a multimeter and you will be good to go. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You can turn up the gains, but only as much as you need. Since I've had my 8053, my comp amp gain has been at minimum, and I listen to it around 55-60 on the volume. So try it first with the gains down all the way, turn the HU up until it's as loud as you'll ever listen to it. I doubt you will get all the way to max volume. If you do, then adjust the gain up a bit and do it again. Keeping the amp gains low will also keep more noise out of your system.
Thanks for the replies.
With my current deck (Eclipse 5341R - 2.7V preouts) I have the gains set just above 1/2 on both amp channels. (Front - DLS MS-5 comps, rear bridged to 10" 11Kv.2) I have the volume/gain set so 60/80 is about as loud as I can stand. I'm guessing that with the new headunit the gains on the amp will be considerably lower for the same amount of volume at 60/80.
With my old/current deck I notice that there is little difference in the volume incrase from 0-38 but from 38-50 the volume jumps A LOT. then from 50-60 the difference is again smaller. It seems to have a small window where the output increases non in a linear way. Anyone else notice this with newer eclipse decks or is it just my old deck?
Thx
Phlipbak
CA Enthusiast
Phlipbak
Dothan, AL; Nashville, TN
mattldm
