Eclipse MK II 7200 won't turn on....
Hayabusa
Audiophile
I installed my Eclipse unit yesterday and everything was all and well. I woke up this morning to go for a joy ride and when i cranked up my deck would not come on. :-( I pulled the deck out and checked both my radio fuses and checked the fuses for the radio under the hook. None of them were blown :-(. my wireing is all secure and connected. What the heck could possiably be the culprit?
I unplugged the harness left it unplugged for like 10 seconds then plugged it in. Still got nothing
did you check constant and switched power at the harness using the ground at the harness as a reference?
do you own a multimeter? If not go buy one. Without knowing if you're missing constant, switched or ground you can guess all ****ing day not and not get anywhere.
Get the right tool, give us the right information, and you will get a lot further.
Set your multimeter to read DC voltage.
Put the black lead on the black wire on your harness.
Put the red lead on the yellow wire on your harness. What's your meter say? Now put the red lead on the red wire on your harness. What's your meter say?
hardness was fine. it read 1 for everything. I took the deck out hooked it up to an alternative power source nothing worked. Tried it on my old deck old deck fired up fine. Hooked my old deck up into the car and it is working just like new. Guess my 7200 is dead after 1 day :-(... My luck sucks.
Hayabusa
Audiophile
Hayabusa
Mississippi
Hayabusa
