Eclipse EA4100 new and cheap
gentlejax
Item(s) for Sale:Eclipse EA4100
Mounted and tested for 30 minutes. Was removed because my friend didnt like the subs he was going to run off his other amp. So he decided to scrap the entire project until he has the time to do it over.
this amp is as new. literally minutes of play time and only on the front channels . was not bridged or anything else. ran a pair of alpines off it.
I may have another for sale later as well. basically new as well. tested for a few days.
Price:$120 shipped
specs:
http://www.sonicelectronix.com/item_9486_Eclipse-EA4100.html
# EA Series 4-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 75 watts x 4 chan.
* Bridged, 4 ohms: 150 watts x 2 chan.
# Max power output: 200 watts x 2 chan.
# MOSFET power supply
# LED power indicators
# Tuned Bass EQ (0-8 dB bass boost)
# The Integrated Amplifier Series offers outstanding sound quality with a distinctive appearance. Audiophile-grade power amplification is featured along with high current MOSFET switching power supplies that combine for dynamic performance with any speaker system
# 4/3/2 channel operation
# High current, high-efficiency MOSFET switching power supply delivers significant power when demanded
# Preamp RCA outputs
# “Easy Tune” top-mounted controls for easily adjusting amplifier parameters even after installation
# Sleek, low-profile appearance with laser-cut top plate allows installation virtually anywhere
# Type of Heatsink (example: Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation)
# Variable high-pass filter (30-500 Hz, 18 dB/octave)
# Variable low-pass filter (50-500 Hz, 18 dB/octave)
# Subsonic Filter ( 18 dB at 18 Hz)
# CEA-2006 compliant amplifier
# Frequency response: 20-20000 Hz
# Dimensions: 13-3/8" L x 10-3/16" W x 2-5/16" H
* EA Series 4-Channel Class AB Car Amplifier
* RMS Power Rating:
o 4 ohms: 75 watts x 4 chan.
o Bridged, 4 ohms: 150 watts x 2 chan.
* Max power output: 200 watts x 2 chan.
* MOSFET power supply
* LED power indicators
* Tuned Bass EQ (0-8 dB bass boost)
* The Integrated Amplifier Series offers outstanding sound quality with a distinctive appearance. Audiophile-grade power amplification is featured along with high current MOSFET switching power supplies that combine for dynamic performance with any speaker system
* 4/3/2 channel operation
* High current, high-efficiency MOSFET switching power supply delivers significant power when demanded
* Preamp RCA outputs
* “Easy Tune” top-mounted controls for easily adjusting amplifier parameters even after installation
* Sleek, low-profile appearance with laser-cut top plate allows installation virtually anywhere
* Type of Heatsink (example: Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation)
* Variable high-pass filter (30-500 Hz, 18 dB/octave)
* Variable low-pass filter (50-500 Hz, 18 dB/octave)
* Subsonic Filter ( 18 dB at 18 Hz)
* CEA-2006 compliant amplifier
* Frequency response: 20-20000 Hz
* Dimensions: 13-3/8" L x 10-3/16" W x 2-5/16" H
gentlejax
gentlejax
Bossier City, La.
gentlejax
