Eclipse DA7232 Near mint!
Drich79
As title states
Cosmetic 9.5/10, Functional 10/10
$400 Obo
Beautiful condition, only a few minor scratches as shown in pictures.
Features:
Maximum power output of 2000W
(both channels) into a 2 Ohm load
Class D optimized for low frequency reproduction
Twin ICEpower amplification modules form the heart of this designed-for-competition subwooofer amplifier
Peak output current in excess of 50A for virtually limitless power
Immense 120dBA dynamic range for effortless reproduction of the lowest frequencies
Built-in protection against over and
under-voltage conditions
Additional protection for amplifier and speakers as well as soft clipping and soft start-up functions
Balanced inputs and outputs
Integrates seamlessly with total system
Quality construction throughout
Detailed Specifications:
Dimensions: 21" x 2" x 11-1/16"
Channels: 2
Power Output (MAX), 10% THD 2 Ohm: 950W x 2
Power Output / 1% THD
2 Ohm: 850W x 2
4 Ohm: 620W x 2
4 Ohm (sub channel): 620W x 2
4 Ohm Bridged: N/A
THD @ Rated Power
2 Ohm:
4 Ohm:
4 Ohm Sub Channel:
S/N Ratio, 1W out: >120 dB
Frequency Response, 1W out: 4 - 200 Hz, +/-1dB @ 4 Ohm
Amp Crossovers:
Hi-Pass 18dB/oct: N/A
Lo-Pass 18dB/oct: 50 - 200 Hz
Subsonic 18dB/oct: Defeat 1 - 60 Hz
Pre-Amp Output Lo-Pass 18dB/oct: 50 - 200 Hz
Eclipse DA7232 were Designed by Bang & Olufsen for Eclipse just so you know. Along with a couple other Eclipse amps.
Killer SQ!
amp that does 950-1000 X 2 @ 2ohm with 0.007% THD? Where else would you find one this clean for the price?
Drich79
Drich79
Omaha
Juggalo423
