Sold Eclipse CD8053 with BLA
SPY
1. Product:
Eclipse CD8053
Eclipse 37601 Balanced Line Adaptor
2. Specs:
Eclipse car audio CD8053 key features
Balanced outputs
High voltage 16V/8V and low impedance outputs
All digital circuitry
STAR DSP (newly designed Digital Signal Processor)
24-bit advanced multi-bit Digital-to-Analog Converter
CD-R/CD-RW compatibility
MP3 playback using optional ECLIPSE Commander Advance
Full dot VF display
Power tilting front panel
Digital input
Auxiliary input
Eclipse car audio CD8053 power output
High voltage 16V/8V Balanced Line Pre-Amp Only
Eclipse car audio CD8053 CD features
CD-R/RW Compatible
ECLIPSE Memory Buffer
CD Text
CD Name Preset
Track Scan
Track Up/Down
Fast Up/Down
Repeat
Random Play
Eclipse car audio CD8053 tuner features
PLL Frequency Synthesized Electric Tuner
ECLIPSE STARTUNER V
24 Station Presets (18FM/6AM)
Preset Scan
Auto Station Memory (ASM)
UP/Down Auto Seek
One-Touch Station Memory
Auto Local/Distant Seek Sensitivity
Eclipse car audio CD8053 audio features
Independent Bass/Mid/Treble Memory for each Source
Balance Control
Fader & Pre-Amp Fader Control
Loudness
Mute
3 Pairs of RCA Pre-Amp Outputs
Specs for the BLA (37601):
Supply Voltage: 13.8V DC (10.8 ~ 15.6V)
Current Consumption Approx: 0.25A max
Frequency Response: 20 ~30.000Hz, ±2dB
Distortion: 0.005% (1Hz, 1V)
S/N Ratio: 106dB (IHF-A network)
Input Impedance: 12kΩ
Output Impedance: 220Ω
Max. Output Voltage: 10V (1kHz)
Common Mode Rejection: 60dB (1kHz)
Dimensions (W × H × D): 6.14˝ × 1.50˝ × 1.97˝ (156 × 38 × 50mm)
Weight: 0.72lbs (0.33kg)
3. Description/Condition:
Used but in good cosmetic and mechanical condition.
Includes HU, cage, trim ring, wire harness, knob remote, credit card remote, and balanced line adaptor.
4. Price: :
$250 + shipping FIRM
5. Pictures:
whats the balanced line out for?
It allows you to run a balanced line (16v) from the HU to where your amps are going to be located and then converts it to an unbalanced (10v) signal for your amps that do not accept a balanced signal.
SPY
SPY
NY
aelareau
