I have a complete sound system that I had installed in my 2007 911 C4 S Cabriolet. I had it removed and had all the factory equipment put back in so the car could be sold as factory certified. Anyways I will list all of the components that I have and if anyone is interested in buying please let me know. Also as far as condition everything was professionally installed and removed and looks and works perfectly. The only flaw are a few marks on the amplifier but nothing major, and I can send pictures if requested.
1) Alpine IVA-W205 2Din DVD/CD/MP3/WMA MOBILE MULTIMEDIA STATION with the PMD-B200 Blackbird Portable Navigation Unit. This was a pretty unique set up the Head Unit does not come standard with navigation but you flip open the display like you are loading a CD and you can pop in your portable nav/mp3 player. The Blackbird can also be removed and used in any car by itself. Along with the Head Unit and Nav I have the iPod Dock cable for full iPod integration. And the Alpine Bluetooth KCE-300BT unit (only needs the microphone.) Everything works seamlessly. I would like to keep these together for simplicity but $Make me an offer.
2) Alpine HD Radio Tuner Module TUA-T500HD, add full HD Radio to your current set up or packaged with anything else I have here. I had XM and used this a lot more.
3) AudioVox XM Protocol Interface Adapter Model CNP2000 UC still has a subscription that doesn't expire for a while at least 6 months possibly longer, I forgot when I set it up. Has the antenna and all cables as well!
4) JL Audio 450/4v2 Four Channel System Amplifier
150 watts RMS x 2 and 75 watts RMS x 2 at 1.5 to 4 ohms
300 watts RMS x 1 and 150 watts RMS x 1 at 3 to 8 ohms
Regulated, Intelligent Power Supply system
Differential-balanced inputs
Variable high-, low-, and band-pass filters (high-pass only on ch. 3 and 4)(50-5000 Hz, 12 or 24 dB/octave)
Switchable bass boost (ch.1 and 2 only) (6 dB at 48 Hz)
Infrasonic filter (ch.1 and 2 only) (24 dB/octave at 30 Hz)
Optional wired remote bass boost (ch.1 and 2 only)
Absolute Symmetry Class-AB amplifier design
MOSFET power and output stages
Speaker- and preamp-level inputs
Preamp outputs
4-gauge power and ground leads and a 60-amp fuse recommended wiring and hardware not included with amplifier
No onboard fuses when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
19-11/16"W x 2-5/16"H x 10-1/16"D
(includes Audio Cables and Power Cables with Fuses)
5) DynAudio ESOTEC MW-182 10" Subs (2)
6) DynAudio ESOTEC MD-142 Mids (2)
7) DynAudio ESOTEC Tweeters (forgot the model number but same group as above speakers) (2)
8) DynAudio ESOTEC X362 Crossovers (2)
All items are described to the best of my ability but if you have any questions please contact me 512-673-0819 or DBittles@yahoo.com I will sell the package for $1200 + Shipping or Best Offer or make me an offer on the individual items. I am located in Dallas, TX
I also have a Calibre K40 fully integrated Radar system that is to be hard wired into the dash of the car for a very very stealth system. Probably the single best radar system you can buy, has front and rear sensors that complete the 360 shield. This should be professionally installed by a K40 dealer due to having the L.E.D.s put in the dash by the gauges.
Preamp outputs
