KyleBechtold
Quit reading this
Anyone ever compare those speaker pads vs the eggcrate or foam(how did you seal this from water)?
That's about it. For any of these things to work in a door, the foam has to be as thick as or for "deflex" type pads the grooves have to be as deep as 1/4 of the wavelength of the frequency you are trying to control. If the material is 1 inch thick, it will be effective with frequencies above 3.4 kHz. Are your door mounted speakers producing anything in that range? If it's 1/4 inch thick it's 13 kHz and above.I did put some in my last car. I haven't really notice a difference beside the fact that virtually, the cone seems more in control. Probably a placebo tough ...
the window is far enough away from the outer panel i could do some foam.. but i won't have lower frequencies coming out of my mids.. well... 60+hz dunno if thats considered low for that.. which would be better?Unless I completely missed it, he's not talking about deadening. He's talking about the deflex pads used behind speakers to break up standing waves and improve midrange response.
Closed cell egg crate (closed cell material is weatherproof, can be found as sleeping bag pads in camping stores) can work very well, as deeper material will help with lower frequencies, but you're probably going to be limited by where the window is.
So should I use a deflex pad over my Overkill pro also in the doors or some accustical closed cell foam or nothing at all?That's about it. For any of these things to work in a door, the foam has to be as thick as or for "deflex" type pads the grooves have to be as deep as 1/4 of the wavelength of the frequency you are trying to control. If the material is 1 inch thick, it will be effective with frequencies above 3.4 kHz. Are your door mounted speakers producing anything in that range? If it's 1/4 inch thick it's 13 kHz and above.
You can't absorb or "break up" the backwave from midrange or midbass speakers in a door. You need to seal the frontwave from the backwave and call it a day.
he is saying nothing will help.. idk though.. i'm not experienced in acousticsSo should I use a deflex pad over my Overkill pro also in the doors or some accustical closed cell foam or nothing at all?
The only constructive use for foam in a door is between the inner skin and the door card to prevent buzzing and rattles. Vibration damper and barriers work great in doors. Anything else between the sheet metal skins isn't going to do enough to be worth doing. MUCH better to cut a baffle out of something solid to mount your speaker to and seal the inner skin the best you can. The only thing you really care about as far as the back wave is concerned is that it not mix with the front wave.So should I use a deflex pad over my Overkill pro also in the doors or some accustical closed cell foam or nothing at all?
