DX745MP or CDA-9847
norcalSRTrida
norcal209
CLARION DXZ745MP or Alpine CDA-9847
ive only got 200max to spend on a hu. and for the price, ive got it down to these two (unless you have any other suggestions).
Alpine CDA-9847
Features:
50W x 4 High Power Amplifier
CD-R/RW Playback
MP3/WMA Playback
3 PreOuts (2V)
Ready for iPod
Bass Engine
Subwoofer Level Control
Bass Center Frequency Control
Bass Band Width Adjustment
Treble Center Frequency Control
BBE Processor
MP3 Text Information Display
CD Shuttle Control Function
MP3 QuickSearch Function
Quad Illumination
Rotary Encoder Volume Control
Regulated 1-Bit DAC
Detachable Trim Plate
Anti-Theft Detachable Front Panel
Wireless Remote Control Ready
DX745MP:
Motorized Detachable Face
Dual 24-Bit DACs
Plays CD-R and CD-RWs
Plays MP3- and WMA-Encoded CDs
Sirius Satellite Radio Ready
CeNET Control of Optional TV Tuner, Sirius Satellite Radio Receiver, Dolby Digital/DTS 5.1 Processor, DVD Changer and 6-Disc CD Changer
CD Text, CD Titling, Station Titling
2-Band Parametric EQ (Z Enhancer Plus)
Subwoofer Volume Control
Built-In Low-Pass Crossovers (off/50Hz /80Hz/120Hz)
4-Volt / 6-Channel Gold-Plated RCA Line Level Output
2 Zone Control With Dedicated RCA Line Level Outputs
Magna Bass EX
ADF
2-Channel Aux. Input
Adjustable Display Contrast
IR Remote Control
212-Watt (53W x 4)
Radio Tuner With 18FM/6AM Presets
728 Variable Color LCD and Control Buttons (12 presets and 3 users)
Retractable Rotary Volume Control
Full-Dot (65x15) Matrix Display
Screen Saver With User-Programmable Message Information
Aluminum Faceplate
Blinking LED for Anti-Theft
Built-In Amplifier Bypass Circuit
the clarion looks more promising, but i thought i'd get a second hand opinion.
hmmm pros and cons. the only thing ive had problems with with my unit is the sat radio. my CeNet thing doesnt work so there for my sat radio doesnt work. it may not have as much control as the newer alpine or eclipse units, but still a great unit
but thats the only thing i have had a problem with. its a great unit. if you get it you will not be dissappointed i promise.
I just ordered the Clarion yesterday..Anyway after searching around here for info on it another thing you might want to know is that it does not have a high pass filter.
whats the down side to this? and what would a high pass filter benefit me w/?
and does the CDA-9847 have it?
high pass filter is a built in crossover. it would keep bass frequencies from going to the speakers. and i dont believe that the alpine has high or low pass filter.
are there any HU's that include a HPF that is around my price range (180-220max)?
and it wouldnt matter if i had this option if i planned on upgrading my components in the future, would it?
i did some better accountable research, and realized i could get alot more/better for the money.
pioneer DEH-P770MP or PANASONIC CQ-C7401U or PANASONIC CQ-C8300U
both panasonics are pretty **** similiar to eachother in price/looks/features...only major difference i could see is just a diff. face plate.
panasonic features:
50 x 4 watt built-in amp
Plays CD/CD-r/CD-RW/MP3/WMA
Motorized Detachable face
High Definition Animated Hot dot matrix display
Built-in 7 band equalizer system with tone controls
Day/night design
Built in High and low pass crossover system
5 Volt Front, rear, and subwoofer pre-amp outputs
CD changer control
Remote control
Mosfet-50w x 4
Memory: 18 fm and 6 am
Frequency response 20hz - 20khz
Sensitivity 11 db
Displays CD and MP3 Text
Spectrum analyzer
Direct track selection
CD changer controls
Alphatuner V
18 FM/6 AM presets
Seek tuning
Rear auxiliary input
Clock
Wireless remote and Wiring Harness
DEH-P770MP
CD Player
1-bit D/A Converter 16-Bit
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Track Title List
CD Text
BMX Digital Enhancement
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 253
Max File # per Folder 99
Max File # per Disc 65535
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9
WMA Bit Rate 48~384kbps, VBR, Lossless
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
IP-Bus System Expandability
IP-Bus System Control
XM Radio Ready
iPod Adapter Ready
Multi-CD Control
DVD Control
TV Tuner Control
Auxiliary Input CD-RB10 or CD-RB20 required
2 External Unit Control
Display Features
Display Type Deep Blue Organic EL (OEL)
Dot Matrix OEL Size 128x32 + 24x32 (Deep Blue)
Screensaver Movies 2 (Dolphin Jigsaw, Circuit Board)
Background Animations 4
Background Pictures 4
Level Indicators 3
Flap Face Flap Face
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Equalizer EEQ (3-band Parametric)
Equalizer Presets 5
User Equalizer Settings 2
EQ-EX
Loudness 3 mode
Automatic Sound Levelizer (ASL)
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network Two-Way Crossover
High-Pass Crossover (HPF) 50/80/125Hz, -12dB/Oct.
Subwoofer Crossover (LPF) 50/80/125Hz, -18dB/Oct., +/-12dB
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (4V), 100 Ohm
General Features
Rotary Volume Control Rotary Commander
Rotary Commander Yes
Remote Control 10-Key Card
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
norcalSRTrida
norcal209
norcalSRTrida
Tracy, Ca
94CamryBumpin
