dual 4 run like 0ga?
because strand count is an indicator of flexibility, not current capacity. you would look at the cross sectional surface area to find the amount of copper in the wire, which would indicate its capabilities.
for instance, the cross sectional surface area of 1/0 is 53.5mm, to get that equivalent, you could use two runs of 3g, four runs of 6g, so on, and so on. all the measurements i used came from here http://en.wikipedia.org/wiki/American_wire_gauge . the cross sectional area of the wire tells you the amount of copper in the wire, letting you know its current carrying capabilities. it doesent matter how you get to your desired cross sectional area, you can use as many wire runs as it takes, the current will be devided equally among them.
and to answer this question about the "rule of thumb"...
http://www.repairfaq.org/REPAIR/F_appfaqk.html#APPFAQK_009
section 17.3 - "Each increase of 3 in the gauge halves the cross sectional area. Each reduction by 3 doubles it. So, 2 AWG 14 wires is like one AWG 11."
Since everyone missed it the first time
Gauge is determined by AREA, not strands or anything else
what if the 4 gauge uses 36gauge strands and the 1/0 gauge uses 36gauge stands also, will strand count come into play in this situation? or surface area is the only way to determine what equals what?
You can go by area, strand count, hell, even amperage. Two 4awg lines will never equal a 1/0awg line.
150a per 4awg line x2 = 300a
350a per 1/0awg line /2 = 175a
ahhh, i was looking at his "formula", not his math, and his math error... i thought you were saying that the rule that he posted was wrong, which it wasnt.
but i must admit, i didnt even notice his math error //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
well I checked it out again and 0ga isnt gonna fit but Im better off running dual 4 than a single 4 right? So I think thats what Im gonna have to do even if its not 0ga . will 2 sets of 4ga fit into a 0ga amp connection?
Yea you would be better off running dual 4 guage. And I would imagine since it takes about 3 pieces of 4 guage to equal 1/0, you should be able to get it in there.
yeah 3 wont fit, but 2 will as long as they are on top of each other and not side by side.
nVRuckus
Banned
nVRuckus
Miami
AJ²06
vegang
vegang
