DSO pocket oscilloscope V1.5
pro-rabbit
Moderator
12,639
OKC, OK
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div~10S/Div (1-2-5 Step)
Horizontal position adjustable with indicator
Vertical sensitivity 10mV/Div~10V/Div (with ×1 probe)
0.5V/Div~100V/Div (with ×10 probe)
Vertical position adjustable with indicator
Input impedance >500KΩ
Max input voltage 80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
Comes with the case also....
$85 shipped
ARGGGGG I want this and I dont even know why!!!!!! Hold it for me til tomorrow man. Gotta see if I can get some cash quick.
As always I have had a ton of interest but nothing solid so I don't see it going any where.
Always good to have a scope laying around. Great tool to use/own. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i want this damnit.....grrrrrrr
buy it lol
everyone in audio should have some sort of scope to help with installs and testing. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have one. Looks nice even though I have never used and am not sure how. GLWS
lol, they are easy to use really. Just take a min to get used to the button layout and such, and thanks..I have tons of PMs and a few emails, but as always nothing I would call serious yet.
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
pro-rabbit
Moderator
pro-rabbit
OKC, OK
pro-rabbit
audiobaun
    May 19, 2024
    May 19, 2024
