DSO pocket oscilloscope V1.5
pro-rabbit
Moderator
12,639
OKC, OK
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div~10S/Div (1-2-5 Step)
Horizontal position adjustable with indicator
Vertical sensitivity 10mV/Div~10V/Div (with ×1 probe)
0.5V/Div~100V/Div (with ×10 probe)
Vertical position adjustable with indicator
Input impedance >500KΩ
Max input voltage 80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
Comes with the case also....
$85 shipped
Lol, not sure what I would do with that amp haha. Yea, I just snagged it to do some messing around with it and then never really used it much. I did update the software and such though.
I was asked to get a better pic of the ends so here it is...
I do have the cover for the end but I have locate it as I think I left that in Amber's car.
toss ya a rockford 501s with end caps for it?. If you have no use you could sell it on ebay for 120+ship easily.
Naw, that is really not worth the extra hassle which that is all ebay is. I only sell items that are rare and worth a decent amount on there as no one here or to many other forums will buy them.
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
pro-rabbit
Moderator
pro-rabbit
OKC, OK
pro-rabbit
Brendon Jenness
    May 8, 2024
    May 8, 2024
