Sold Download and convert YouTube videos
style197
Have you already found a proper way to download and convert YouTube videos? If haven’t, this guide will show you how to do it via the help of
Pavtube YouTube Converter. Please feel free to follow its step-by-step instruction as long
as you are in need.
Step 1: Download, install and launch Pavtube YouTube converter
As long as you run this program, the following main interface will pop up:
Step 2: Add URL, select output format and specify save path
Click on tag “Add URL” on the main interface as above, and then copy and paste the URL of the YouTube videos which you want to download and
convert to the text box after “URL”. By the way, if you want to keep the original FLV files as well as the converted files, you can tick
“Keep FLV source file”, if you just need download YouTube videos without format changing, you can tick checkbox “Only Download FLV source
file” to achieve it.
This interface also allows you to set output file name via typing it into the text box after “Save as”, and you can specify where to save
the output files by clicking on the ellipsis icon at the opposite side of “Save to”. The two options are optional, if you do not set them,
the program will produce a file name and save path automatically by default.
Moreover, you can click on the drop-down button after “Convert to” to select the output file format. Look at the interface below, there are
various options, you can choose whatever format according to your own requirements, here I select iPhone MP4 for instance:
Step 3: Custom
If you have higher expectation of the output files, you can click on “Custom” to adjust video and audio parameters like bit rate, frame
rate, sample rate, etc. If not, just skip this step.
Step 4: Download and convert
Once all settings are completed, just click “OK” to start, and the following interface will show you the downloading and converting info in
detail:
After finished, you can click “Open” to find out the downloaded raw FLV files and the converted files with ease.
And what makes you think that this needed to be posted in the classifieds part of this car auido forum. when you posted this did you not see that everyone else has posted car audio for sale or trade, not how to computer stuff. Get it right next time.
style197
style197
London
Annnarbor84
