Guys, you are forgetting one MAJOR factor here.
When you lengthen the port, you are going to take up airspace (given that the port is internal, which I'm assuming it is).
If you make the box smaller and keep the port area the same, the port needs to be longer to maintain the SAME tuning as the larger box.
Thus, you are counteracting the work you've done.
If you want to make the tuning lower while using the same box, you're going to have to cut down on the port area if you want to make a noticeable difference. You can add an inch or two and drop the tuning 1-2hz without really affecting the airspace, but I highly doubt you'll notice a difference in performance.
And to answer your question OP, no there is not one formula to figure out how to lower your tuning 1 hz. And odds are you'll never hear such a minuscule difference anyways.
