Well I have a daily driver that has a couple blown factory speakers in it.
The car all factory speakers in it now.
I plan on just replacing the speakers with Coaxial speakers because they are cheaper and this car is just a beater.
The car takes 5.25 speakers in all the door and back hatch.
The speakers I came across are SoundStorm LS52 .
I will be powering the speakers off the Head unit itself.
The headunit is a Kenwood KDC-138.
I could order 2 pairs of them for $28 shipped.
So that will do all 4 doors.
I am sure they will be better then my blown factory speakers but I just want some peoples opinions.
The car by the way is a 1993 Dodge Shadow ES.
Well thanks for all your advice in advance.SoundStorm LS52 Poly-coated paper cone
Santoprene surround
High temperature aluminum voice coil
Mylar dome tweeter
Peak power handling: 250W
Magnet structure: 25 Oz.
Efficiency: 90dB (1 Watt/1 Meter)
Impedance: 4 ohm
Frequency response: 85Hz-20kHz
Mounting depth: 1-15/16"
Car speakers are usually sold as a pair unless otherwise noted.
UPC: 791489000000
Weight: 3.42
