Do I have a blown head gasket?
I know this isnt really the right forum for this but ive just been wondering since I just finished my whole system in this car. Its a 96 honda accord and I noticed bubbling and the coolant spills out if you rev the engine in the radiator.
I dont have white smoke coming out of the exhaust, oil looks fine, spark plugs look fine. I even did a compression test which came out to 184, 189, 178, 180.
Could a leaking/bad heater core make the coolant bubble and spill out?
thanks
its completely normal. You'd know if you'd had a head gasket leaking, there would be water mixed in with your oil (turning it milky) or straight up steam comming out the exhaust. It really depends on where the gasket breach happens for each symptom
Is the car over heating? Bubbles in the radiator when reving the motor means you are building pressure (or trying too) or a combination of boil temp, when you have bubbles at idle and they have a grey tinge to them then yes you have a leak.
You can go to Autozone and get it checked, most of them have the blue liquid kit that can tell you if you have a leak by changing the blue fluid to green.
Its somewhat over heated 3 times this month but I think thats because Ive had some coolant loss. But it doesnt keep rising up. It stays stable just a little under half way when it does over heat.
Really, I was reading up on that but didnt know autozone did that test. Ill have to check with them tomorrow then. Thanks
Its normal? I thought the coolant was suppose to get suucked in when you rev the engine? I dont have any of those symptoms though.
wait, it is bubbling over the spout when the cap is off? or it is releasing pressure into the reservoir? if it is releasing into the reservoir, check that the spring in the radiator cap is still tight and not releasing prematurely. next, check that the thermostat is installed correctly. Some of them have a small valve that releases pressure and if the thermostat is installed with that valve rotated toward the bottom, it will make the temp rise until you give the car some gas. Also, the thermostat could be installed backwards. If all that is okay, I would possibly check the water pump. If there is no water in the oil (looks like milkshake if there is), then there isn't a lot to worry about.
It won't get sucked in oftentimes. As the engine heats, the fluid expands and spills out of the radiator so you want to keep it capped.
Its with the cap off. You'll see a couple of bubbles popping every now and then and when you rev up the engine, the coolant just spills out. It doesnt gush out or anything, just calmly spills out. I can just replace the thermostat while Im at it.
My oil looks pretty good, its just a bit dirty but looks normal to me. Also whenever the car over heated (not a major over heat,) it cools back down when I rev the engine.
If its cooling back down when revd waterpump is cycling the coolant. You can have a leak ome were and getting air in the coolant causing the bubbles. Also make sure that the fan is working properly. Theres a reason you overheated 3 times
test the rad. cap, bleed the radiator to make sure there is no air pockets in it. after that if its still doing it change the water pump, then thermostat
all of that might run you 50$ max if u still having issues bring it to a rad. shop and have them check it out for you.
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
ideal concepts
