as title states OBO .. open to CASH offers or trade for an RE XXX 12" .. 04/05 model
ought these both off the forums and never used them. Before I installed these I changed my mind on going 2way active to 3way active so these got replaced with an A4 and A6. I've got a 2nd A3 so this was the spare.
The A5 is near mint minus the bend in the top of the heatsink and mounting tab.
The A3 has wear and tear. The person I bought it from drilled holes in the bottom for fans.
Only trades are for another DLS A6 or A4 or an 04/05 XXX 12"
A5 - $350 shipped
A3 - $325 shipped
A3
* RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
* Mode : AB
* Number of channels : 2
* Output power in 4 ohm : 2 x 150 watt
* Output power in 2 ohm : 2 x 270 Watt
* Output power in 1 ohm : 2 x 425 Watt
* Output power in 4 ohm bridge mode : 550 Watt
* Output power in 2 ohm bridge mode : 870 Watt
* Output power in 1 ohm bridge mode : 1200 watt
* S / N ratio, A-weighted : > 100 dB
* Damping factor : > 200
* Input impedance : > 10 kohm
* Input sensitivity, variable : 0,2 - 7 V
* Filter, highpass, variable : 20 - 200 Hz
* Filter lowpass, variable : 50-125 Hz
* Terminal for external cooling fan : Yes
* Double DC-inputs : Yes
* Phase shift button : Yes
* Current draw, idle : 1,1 A
* Current draw, maximum : 140 A
* Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
A5
* Mode : AB
* Number of channels : 3
* Output power in 4 ohm : 2 x 85 W
* Output power in 2 ohm : 2 x 100 W
* Mono channel, ouput power in 4 ohm : 300 W
* Mono channel, output power in 2 ohm : 500 W
* Mono channel, output power in 1 ohm : 780 W
* Filter, front channels : Highpass: 50-125 Hz
* Filter, mono channel : Lowpass: 40-90 Hz. Subsonic: 25 Hz
* Phase shift control 0-180 degr. : Yes
* Remote sub level control with phase control : Yes
* Dual DC-inputs : No
* Current draw, idle : 0,5 A
* Current draw, maximum : 90 A
Heres all the pics http://s535.photobucket.com/albums/ee359/frkkevin/dls%20amps%20for%20sale/
A5 - $350 shipped
A3 - $325 shipped
A3
* Mode : AB
A5
* Mode : AB
