Sold DLS A7 " The big 5" F/S MINT Condition
ill get actual pics when i can but this is what it looks like
zoom
Number of channels 5
Amplifier class AB
Output power in 4 ohm 4 x 60 W
Output power in 2 ohm 4 x 100 W
Mono bridge mode 4 ohm 2 x 200 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 440 W
Mono sub channel output in 1 ohm 600 W
Frequency range 10 Hz - 50 kHz
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,3 - 7 V
Input impedance > 10 kohm
Filters channel A & B HP: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filters channel C & D HP: 80 - 400 Hz. LP: 0,3 - 4 kHz / 3 - 40 kHz (x10)
External cooling fan terminal 1
Remote base level control 1
Remote phase shift control 1
Power consumption (idle) 1,1A
Power consumption (max) 120 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 35 A + 2 x 20 A
Dimension (W x D x H) 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inches)
Weight 8,1 kg ( 17,86 lb)
mobeious
what does 0hz feel like?
mobeious
Bartow, FL
mobeious
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
