I have a Used DLS A6. I was installed in one of my customer Chevy Tahoe under the rear seats. Some tried to steal his system and when they was trying to get the amp the RCA were screwed on pretty tight and the pulled the RCA jack a loose from the board. I replace the RCA Jack with standard type jacks. The amp was a little rough looking so I saw the chance to see how the Ultimate Amps would look in Black and it looks great. While not perfect as the heat sink had some imperfection in it. There are small little pin hole looking imperfection. Hard to see in the photos. I would have to gvie the amp a 7/10 in condition because of the imperfection. It works 100%
DLS - Products
$225 shipped.
I have a couple Brand New in Box (plastic wrapping still around box, never even been out the boxes) Alto Mobile Fullrange Class D amps. These are the best sounding Class D amps I have ever listen to or used and some the the best sounding midrange amps period. These are small with great power and sound great. Some of the best midrange amps I have used, somewhat of a tube like warm sound. These amp are not 2 ohm stable, but they make the same amount of power into 4, 8, 16, or 32 ohms, However the can be bridge, but only input 8 ohms or higher!!!!!! Great for those of us who are using home or pro audio drivers.
http://i69.photobucket.com/albums/i7...e/DSC02695.jpg
THD:………………………………………………….0.05% @10Vrms
Residual Noise:……………………………………
Xover:………………………………………………. HP/ LP/ FLAT switchable. 50Hz - 500Hz, 12dB/oct.
Input Gain Range (MAX - MIN):…………………400mV to >15V
Operating Voltage:……………………………….11 - 16V DC (negative ground)
Output Efficiency at Full Power:………………>90%
Protection Circuitry:……………………………..current (LS output), voltage (+/-), temperature
Idle Current (no signal):…………………………0.6A
Standby Current, REM input low:………………1mA
Size:…………………………………………………229 x 175 x 37mm (9” x 7” x 1.5”)
2 150m mono: 150 x 1. $155 shipped each in the US. (These I truly don't want to sell, but it is for the great good)
I have Mint set of Hertz Space 1 1" soft dome tweeters. These are some of my favorite small format tweeters. These are the same tweeters as the ML28 tweeters to comes in the Hertz MLK165 comp set, just with an all black grille.
$145 shipped in the US.
I have a Mint set of the Hertz CX20 Passive crossovers. These are the Passive that come with the MLK165 comp set. Great passive units. With the above tweeters and I nice mid/bass driver (The H-Audio Ebony's are a outstanding match for the this set. Sorry for the shameless plug!)
70 shipped in the US.
Near Mint Eclipse 5303R. Love these unit as many now I an old school Eclipse head unit fan. The unit is Near Mint. I have the manual, cage, wiring harness, remotre and trim ring, everything but the original box, but you will get it in a eclipse box.
$115 shipped in the US.
Eclipse DDL (Direct Digital Link) system some else I said I would never sell, I was going to use it in an old school build I had planned, but here it is. You get a system the is in very good condition for its age. You get everything but the ECD-510 head unit (which I’m keeping).It can be used with any head units as it has analog input Or you can use it with any source that has a toslink optical output, Also the Changer has optical out so you really don’t need a head as it can be controlled from the EQR-2140, DDL Touch Logic Controller. It has to many features to list, see the link below for full specs and info. Come with all cables need for connection.
$220 shipped in the US.
I have a set of the TBI HDSS Tweeters. I change the color to a saint black, looks really.
50 shipped in the US.
I have 5 units of the super rare MIT AutoTerminator Pro Speaker Articulation Modules some more items I said I would never sell.
These units are of direct origin from the Award winning MIT Oracle Technology. They where marketed for Auto Audio used, but can be used in either Home or Auto. These unit where available in 3 levels, Street units (entry level), Competition units (audiophile level) and the Cream of the crop Pro units ( Epert/on holds bore Level). What you see here are the PRO units!! These units had a retail value of $1200 for the pair. What I have are 2 High/mid units in chrome which where the production units. I also have 2 more High/mid units, but are in the prototype casing and lastly 1 Mid/low unit in the Prototype casing. That’s 5 units in total, that’s a whooping $3000 in modules.
$350 shipped in the US.
I have a used Pioneer FH-P4200MP Double Din CD/Cassette (I said Cassette ) Player. I give this unit a 9/10 only because it is a very small mark on the face directly under the model number. Other then that is perfect. It was used for only one month maybe a little less.
DLS - Products
$225 shipped.
