Sold distro block for 5 runs of 1/0 plus more
psychoacoustics
hammer and the evil one
aluminium distro blocks 50$ for the pair
2" x 1.5" x 6"
(5) 1/2" holes (plenty of room for hyperflex 1/0 or 2 smaller wires or even one from each side)that go all the way through the 1.5" with brass 3/16" set screw for wire hold down on the top
(1) 3/8 threaded tap on one end perfect for a ring terminal for mids high amp or other accessory includes bolt
2 holes for mounting
lots more pictures in the folder taken out in the sun for a better view
http://s232.photobucket.com/albums/ee266/psychoacoustics/wire/?start=all
4/0 ring terminals with 2 holes for a way better contact 12$ for the pair
dual 4/0 distribution blocks these will bolt right on a side terminal of a 34/78 yelow top or on the top of a powermaster or kinetik and hod 2-6 power wires each they have 2 7/8" holes and a huge set screw 15$ each
tons of more styles of distro blocks and great grounding terminals
not just a cheap ring terminal with 3 screws through the sheet metal
2$ each or cheaper if you buy more
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
