Will this distro block be ok if I want to add another amp to power my door speakers? Im running 4 gauge wire from the battery to a "300W x 1" sub amp.
So Ill run the 4 gauge wire into the distro block, 8 gauge wire to each amp right. What gauge wire should I use for ground from each amp, 4 or 8 gauge?
As far as the amp remote wire goes ... since the current amp's remote wire is already connected to the HU, can I connect the new amp's remote to the existing amp's remote lead or should I run another remote wire to the HU for the new amp?
Will I need anything else to add a second amp?
Let me know if I left out any info that might help. Thanks in advanced.
OC
OC
