I have a relay set up for my fans/amps. The relay is going into the distro block and squeezed in with the 8 gauge ground & powers for my 4-channel amp. So far this works fine. I have 2 issues though:
1. I need to get new ground & power distro blocks. The ones I have now suuuuuuuuck. I was looking at the knukonceptz's blocks, but I'm not sure if I can use these to power the relay, since they have some crazy "kompression" method of installing the wires to the block. Do you guys have experience with these blocks?...do you think I could stick in my other power & ground from my relay with them and not worry about them working their way out?
2. I need some sort of small (fused, if possible) distro block for my fans & amps' remote turn-on wire coming from the relay. I've searched partsexpress but couldn't find anything. Right now they're all connected through a butt-end connector. Relay wire going in, 4 wires (2 fans, 2 amps) going out.
Here's a link to the distro block, it's pretty cool, just not sure if I can plug my relay's into them securely.
http://www.knukonceptz.com/assets/Tech/knfhowto.pdf
