disable password windows xp
im on it for 30 min a day she just like 2 has control and is a bitC
Then dump her y0! No *** is that good.
Well....maybe it is, but I say dump her anyways....
Otherwise, look for something called EBCD. Use it to crack the admin password and create you a new admin account to use for yourself. Here's the info on it:
EBCD – Emergency Boot CD (v0.61 - October 2004)
EBCD is a bootable CD, intended for system recovery in the case of software or hardware faults. It is able to create backup copies of normally working system and restore system to saved state. It contains the best system software ever created, properly compiled and configured for the maximum efficient use.
EBCD will be very useful when you need to:
Copy/move files (with long names, not necessary in CP437 encoding) from/to the disk but OS which can handle them (windows, Linux...) cannot boot. In particular, you may create a backup copy of normally installed and configured Windows and later restore Windows from such backup copy. So, in the case of fault OS itself and all software and its settings can be restored in 5-10 minutes.
Perform emergency boot of Windows NT / 2000 / XP. When the loader of this OS on the hard disk is damaged or misconfigured, you are able to load OS using another, standalone loader from this CD.
Recover master boot record of HDD. This allows to boot OS after incorrect uninstallation of custom loader (LILO, for example), which made all OS on your PC not bootable.
Delete, move, copy to file (image) and re-create partition from file. Image transfer over network is also supported: so you may configure one PC and then make contents of hard disks of other PCs same as contents of the hard disk of the first one.
Change password of any user, including administrator of Windows NT/2000/XP OS. You do not need to know the old password.
Recover deleted file, even file re-deleted from Windows Recycle Bin, and, in contrast, wipe single file or a whole disk so that it will be impossible to recover it in any way.
Recover data from accidentally formatted disk. Sometimes it helps to recover data from the disk, damaged by a virus.
Recover data from a floppy disk, which is not readable by OS. Format 3.5" disk for 1.7 Mb size.
Also the disk includes full set of external DOS commands, console versions of the most popular archivers/compressors.
Moreover, emergency boot CD includes minimal Linux distribution (Rescue Linux distribution) which may be very useful to a professional user.
Read more at http://ebcd.pcministry.com
Download links:
EBCD Pro distribution (18mb)
When she does let you on it, Start > Run ... > control userpasswords2 > Unselect "Users must enter a password to use this computer" > Click OK
She'll never know how to re-enable it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Haha, thats an excellent idea too, I forgot about that commandline function. She'll never prove it was you, I don't think thats a very common function.
You forget she'll have to put the password in there or else whenever the computer goes to automatically log in, it will say "incorrect password" and you'll have to enter it anyway.
Jmac, I didn't pick up the association with the first suggestion, my bad //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
unplug ur mouse and keyboard and when shes freaking out on why it doesnt work tell her i told you u should have givein me the password now its to late or unplug the cpu fan wire inside and it wont boot that would freak her out lol make her think she broke it
Then dump her y0! No *** is that good. Well....maybe it is, but I say dump her anyways....
Download links:
Something similar to this is austrumi-0.9.2 google it if above doesn't work
corto
corto
Flint, Michigan, United States
pervertatoid
