Directed Electronics 1100d Car Amplifier
c_nitty
Item(s) for Sale:Directed Electronics 1100d Car Amplifier
Item(s) Description/Condition:Directed 1100d Class D Mono Amplifier works like new marks on top of the amp but this things a beast!
In 2001, Directed's class leading three class D models combined added up to almost 2KW of power, and for 2002 that is more than doubled to over 4KW, and the new 2400d has enough power to run most major appliances, coming in at an incredible 2.4 KW!
High speed MOSFET switching power supply
High current complementary MOSFET outputs stable into 1 ohm loads*
Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection with status LED †
Master/slave RCA jack functions support two amps bridged to one load**, or multiple amps driving separate loads with synced gain †
Top-mounted controls easily accessed for system tuning †
Continuously variable 18 dB/octave low-pass crossover ¤
Switchable 30 Hz, 24 dB/octave subsonic
filter †
Switchable 8 dB bass EQ function
Switchable phase invert function
Remote subwoofer level control ‡
* models 2400d and 250d stable into 2 ohm
** 600d, 1100d
¤ 250d 12dB/octave
† all models excluding 250d
‡ optional on 250d
Dynamic Power Rating: 1400 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 425 x 1
Rated Power @ 2 ohm: 800 x 1
Rated Power @ 1 ohm: 1100 x 1
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
Price:$145
Shipping and Miscellaneous Item Information:Free
real nice amps. you can pretty much cook these and they keep on ticking. btw, peak is 1400@1 ohm, which is a good thing, because the output is real solid and stable. i'm real strapped right now, or i would pick this one up to strap to my other 3
just 2 of theese, a telephone wire splitter bass knob, 4-wire phone cord, and you bridge them with a jumper on the speaker terminals, and single rca jumper.... pretty simple
edit: do not need a splitter, the 2002 does not use a bass knob split to the slave, just the master, so the single one that came with them works plugged into the master only. everything else remains the same, though.
c_nitty
c_nitty
Houston,Tx 77044
unbonyr
