southpoleman69
real quick explanation, dont need a lot of detail, jw whats the difference, if any?
quoted above is from the link.Some very expensive high-end equipment features balanced inputs. Most of these are gimmicks. The reason is that in order to compare the two signals, you literally have to have two amplifiers for every one. What most high-end equipment manufacturers do is they provide balanced connectors (called XLR connectors) and then convert this to a standard signal. The benifity is that it allows you to use XLR connectors instead of RCA connectors. It doesn't offfer the ability to drive longer cables and eliminate noise.
NOPE!!! They're just more efficient. Class A amps are some of the best sounding amps on the planet. Not to say in the least that full range class d amps can't sound good.so class d amps really are better than the other classes.
