Chris02NeonSXT
Alright I was wiring and hooking up some of my NEW equipment today, which included an xtant a3001 and a hifonics falcon amp. I ran a 4 gauge power wire this this dist block:
Which had a 4 gauge going into the xtant, and an 8 going into the hifonics. I payed no attention to the material the dist block was made out of and where I was placing it, but when I reconnected my power wire to the battery, it sparked like crazy.
What I think happened is the dist block grounded out the the floor pan where I have it installed because the base of it it made out of some type of metal. After this happened I covered the base in electrical tape and I had no problems when hooking up the power wire.
At the time I had a 120a fuse 8" from the battery.
As you may suspect, neither of my amps' power LEDs are lighting up. The Hifonics had a 30a fuse on the amp itself. The xtant did not have a fuse on the amp itself. I replaced the 30a fuse on the hifonics with a 40a (all that I had laying around) and still no dice. I changed the inline fuse on the main 4 gauge power wire and still no dice.
Did i freakin fry my two brand new amps?
Thanks,
Chris
Thanks,
Chris
