DEI avatal 4100 questions
NhustlaR
Below me
I am lost as to where the satellite hookups go....
It's going in a 99 saturn. No stock security system, no power locks, not hooking up the trunk pop..
Any tips to where these go or if they need to be on relays?
any other tips would be appreciated. So i need to hook up relays on anything if i'm not hooking up door locks or trunk pop?
It's my first attempt at a remote start so bear with me
Thanks
Nick
ok i know the status output can be hooked to a relay for the anti-grind..... but still lost on all of the trigger wires.
also where should the activation input be hooked to?
sorry for all the newb ?s.... I thought it would be a lot easier to **** with than it is.
o you dont need that harness, you would use the status ouput if you had a bypass module. and the activation input doesnt get hooked up it is for if you wanted to put a button in the car to start it with the remote start system.
NhustlaR
Below me
NhustlaR
Brockport, NY
NhustlaR
