Did you already have a layer of closed cell foam behind the speaker? I have been wondering whether they accomplish substantially the same thing.I noticed quite a bit of difference by adding a deflex pad. It really smoothed out my midrange which was pretty nasty at the time. It also got rid of a ringing sound I was getting on some songs (mainly Moonlight Sonata and Vesti la Giubba - Pagliacci by Pavarotti).
They don't. Deflex (product of Cascade Audio Engineering, not the generic term) pads defract and scatter sound waves through the the series of concentric rings on the surface, thus reducing the amount of back wave cancellation. They are made from a low derometer rubber with isn't very good at sound wave absorption, but great for that particular application. They work best when installed directly behind the driver at 15* off axis from the radiating wave.Did you already have a layer of closed cell foam behind the speaker? I have been wondering whether they accomplish substantially the same thing.
Im curious how you arrived at the numbers you did. For example, I know the actual density of the foam will affect its performance, yet you didn't seem to have that as part of your math.They don't. Deflex (product of Cascade Audio Engineering, not the generic term) pads defract and scatter sound waves through the the series of concentric rings on the surface, thus reducing the amount of back wave cancellation. They are made from a low derometer rubber with isn't very good at sound wave absorption, but great for that particular application. They work best when installed directly behind the driver at 15* off axis from the radiating wave.
Closed-cell foam is an absorber and it's job depends directly on its thickness and the frequency in question. So, for your typical midrange driver playing from 50hz - 3khz a piece of 1" CC foam would get you down to about 1k at 100% absorption and then fractionally less as the wavelengths get longer.
No, I have no deadening done except for the pads. But like mentioned above, they do not function the same way.Did you already have a layer of closed cell foam behind the speaker? I have been wondering whether they accomplish substantially the same thing.
