Debating on an SPL enclosure in my truck
Now ur talkin....18s are for suckers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Even though I'm not competing right now, one of my 18 boxes is in the MECA S3 class:D 152.1 dB @ headrest off of 165A of true fusing.
Wouldn't it matter in the sense of almost using it like a bandpass? Where the sub and/or port is loading off of the floor?
Yeah the sub uses objects to load off of. However, the sub doesn't have to be right next to something in order for it to load properly. There are many SPL vehicles out there, such as CRX's, where the subs can be a great distance away from a solid object. Most of those guys in DB Drag w/ CRX's run the subs forward, firing into the dash. I have also seen many guys do well over 150's in SUV's with the subs forward, with there being at least a 6 ft gap from a solid object.
The trick to SPL is to stop over analyzing everything. I used to try to understand all the physics in the beginning, and it cost me score because I wouldn't open up my mind to new ideas. Once you open your mind to new ideas, work hard, and try new things (even if you doubt they will work) you will learn your vehicle and your score will increase.
Sounds like a good theory. Well, really I'm trying to see if this is worth trying because I've tried every other way so far, except for that. My truck likes side firing.
Buck
little alien on campus
Buck
Inside of a pyramid
bhsdriller
