DDZ2 initial numbers OMG.
Man I never listen to soundpressures test anymore after they said they got 1600w at 1 ohm out of an m1
that # may bot be to far off tho...1ohm reactive anyway.
a single m1 stomped a vr1000 by over a full db on 4 LI 12"s a waaaays back..My former buddy swapped four jl 1000/1's for 4 M1's and there was a night and day difference.
how about some 14v numbers? i could care less about 16...
again, from soundpressure:
Z1 is more stable then the Z2 in a 12 volt system.
And Z1 gives out a little more power in a 12 volt system then Z2.
But @ a 16 volt system the Z2 gives out alot, almost Z1 x 2 in max power
12.5 volt 60Hz "one 12 volt 100Ah battery"
DD Z1
2279w/max @ 4.6 ohm
3405w/max @ 2.3 ohm
4188w/max @ 1.15 ohm
DD Z2
2045w/max @ 4.6 ohm
3260w/max @ 2.3 ohm
na @ 1.15 ohm The amp is going in protect, not enough power in the battery.
djman37
SOLID
djman37
DFW, TX
iagrdshaka
