SOLD DD9515D Dual 1
  • 2
SVT Cobra
I have this DD9515D Dual 1 has a fresh recone and the CF dustcap. Has not seen power since recone. It's in mint condition. Pics available. Here's some specs:
Series
9500d
Woofer Diameter
15"
Voice Coil Diameter
3"
Voice Coil Type
4 layer DVC
Magnet Weight
300 oz
Cone Type
Synthetic Fiber Blend
Power Handling RMS
1200
Power Handling Music
2400
Power Handling Peak
4800
Suspension
75 mm
Nominal Impedance
Dual 1 Ohm
DC Resistance
1.0 Ohm
Free Air Resonance
33 Hz
Qts
0.29
Qes
0.31
Qms
4.32
Vas
85 L
Le mH
0.9
Sensitivity
93 dB
Mounting Depth
8 3/8"
Cut Out Diameter
14"
Speaker Weight
49 lbs
CNC machined motor structure
300 oz black chrome edge treated magnet
3" DVC voice coil with 1200 watts continuous power handling
Free Flow Cooling System integrated into the motor structure
Multi-layer synthetic spider suspension
Proprietary EROM (Extended Range of Motion) surround
SFB cone stock - Synthetic Fiber Blend
Carbon fiber/Epoxy cone stiffening disc, 4 layer hand laminated
$325 Shipped or trade. //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
i have a 9512 but that's useless....why would u go down size...
aniways a bump nonetheless
Thanks for the bump man. But no1 is really interested in this sub lol. It's in mint condition,hasn't seen power since recone from DD.
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
834
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
830
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
938
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
SVT Cobra
SVT Cobra
California
SVT Cobra
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
