http://www.putfile.com/album/160443 -Yes, the pictures are old but I can get new ones today if absolutely needed.
Yes, there's a chip in the magnet but it's not a big deal. Has a CF dust cap and dual 2 coils and no, I can't test the coils as my DMM is broken. The one issue it had was that it was clicking a bit because the spider was rubbing on the layering on the underside of the cone which I fixed using CA glue around the spider to the cone joint. Using a 9volt battery I did the pop test and both coils worked and no noises as far as scratching goes can be heard. I'm getting rid of this cheap because I'm not using it and my apartment isn't exactly the best place to be storing lots of things. I will not deliver it but I'll meet you within 5 minutes from my home.
