DD 1508 T/S parameters
DD 1508 SVC 4 ohm
Revc = 3.6943 ohms
Fms = 52.0803 Hz
Zmax = 44.8851 ohms
Qes = 0.7747
Qms = 8.6373
Qts = 0.7109
Le = 3.7049 mH (at 1 kHz)
Diam = 165.1000 mm ( 6.5000 in )
Sd =21408.3884 mm^2( 33.1831 in^2)
Vas = 4.5034 L ( 0.1590 ft^3)
BL = 14.5155 N/A
Mms = 135.0167 g
Cms = 69.1681 uM/N
Kms =14457.5410 N/M
Rms = 5.1152 R mechanical
Efficiency = 0.0772 %
Sensitivity= 80.8920 dB @1W/1m
Sensitivity= 84.2477 dB @2.83Vrms/1m
I'm trying to prepare for a comp coming up on Oct. 21st... I was suggested by our local DD dealer to make a box tuned to 45hz (he didn't specify cubes) but I wanted to try to figure out what would be best, myself. It's gonna go into a '91 corolla sedan trunk that gives me, at most, 3 cubes to play with, i believe. I've got 2 1508's to play with and hopefully I get my cadence zrs10 from CA.com by the 21st (I'm currently amp-less). Right now, they're in a 2 cube box tuned to 40Hz.
After playing tones in their current box from 30-60Hz, I notice good "by-ear" responses on 32hz w/out vibration from the car. Once I hit 40-55hz, I can hear it get louder but I'm getting a ton of vibration from the car. So now i'm wondering how to approach the situation with the time I have left til the 21st. Sound dampening the trunk fully and keep my current box, or build a bigger/higher or lower-tuned box and leave just my trunk lid deadened?
DD 1508 SVC 4 ohmRevc = 3.6943 ohms
Fms = 52.0803 Hz
Zmax = 44.8851 ohms
Qes = 0.7747
Qms = 8.6373
Qts = 0.7109
BL = 14.5155 N/A
Mms = 135.0167 g
Cms = 69.1681 uM/N
Kms =14457.5410 N/M
Thanks man! I'll see what I can come up with now. But if anyone read my last post before this and thinks they can help, feel free to send me a PM or reply to this post.
If it is 2 cu ft total counting the port they should be fine...I run mine tuned at 40hz...16 sq inch port per cu. ft
Alright... yes my box is 2 cubes, port included.
I'll play around w/ the T/S params anyway but I guess I'll keep my box the way it is and concentrate on deadening the trunk as much as possible before the comp.
type[s5]
Aspiring Car Audiophile
type[s5]
Waipahu, HI
type[s5]
vegang
vegang
